Projector problem
Weekell75
I need your help. When I connect my Inspiron laptop to my projector, the image displays perfectly on the wall, but the screen of my laptop is blank!
Can anyone help? It is much harder to navigate this way.
Thanks!
Piece of cake. connect porjector use the Win key + P key when options come up pick the one that displays on both
BTW I have inpiron as well
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Ken
Thanks Ken!! Unfortunately I am a bit thick with computers - can you tell me in more detail? What is the Win key? Will options come up on the display on the wall or on my laptop screen?
I'm sure Ken has it down. I always use the Function (Fn) key in conjunction with the CRT key (that's on one of the top numbers - it may vary). This toggles from pc only, output video only, both pc and output.
The Win key Ken mentioned is the key with the Microsoft logo on it. Usually bottom left of keyboard.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
