project - build home made harddrive
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Thanks Bassfisher for sharing this.
But I have few opinions about it. What's the point in using the case from the big hard drive if we can use any other plastic box that should do the same, I mean...it will hide the hub and the flash drives inside. I'm sure such setup would look nicer than just bare 3.5' drive sitting on the table.
The second is, why can we use stock flash card and /or pendrive with 32GB or more capacity? They also will use the USB port to connect to the system, right? They already look great, they are small and fit into any modern system. I think they cost almost the same as the needed components in this project. And what's most important we don't have do anything, they are ready to use from the box.
That's my two cents. Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
i don't trust myself for taking things apart :confused: lol i would mess anything up or who knows what!!
Dom
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
Thanks bassfisher, I'm certainly going to try this as I have a 10GB HD in my garage.
EDIT: I jumped in too quick, if I go through this project I'll be spending £46 for a meagre 20GB,my 10GB HD deserves to go to skip:D
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
