"Programs and Features" Question
tommygun
Hi.
Can someone of you guys tell me where the folder is located that contains the files or shortcuts that show up in the "Programs and Features" window?
Any help is greatly appreciated.
Thanks in advance,
Hi.
Thanks in advance,
As far as I can tell, the "Programs and Features" list is hard coded, depending on which version of Vista you have.
Is there any particular reason you need to know in which "folder" it is stored?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Hi.
Thanks in advance,
.......thanks for the very quick reply.
I'm using Vista Home Premium 32Bit and there is no particular reason but I was wondering a long time ago where this folder is located that contains these files or shortcuts.
The way I understand it is that the icons that show up in the "Programs and Features" window are only shortcuts to the program uninstallers.
Anyway, I would like to know for sure how this works and where the folder is located that stores the data.
Maybe you can shed some light on this subject.
Thanks again.......
You're welcome Tommy.
