Problems with uninstalling some programs
Dibdab
Hi
Ive been having a few problems with uninstalling some programs via the add/remove programs tool. For example I have been trying to uninstall Itunes and everytime I do Windows installer says it is preparing to remove and then it stops and a window come up that says "The system administrator has set policies to prevent this installation." and then another one says I do not have sufficient access to uninstall Itunes and to please contact system administrator.
So I spoke to a friend how recommended this forum subject and I followed the Take Ownership steps a few times but to no avail it still does the same thing. I can't update Itunes untill this one is uninstalled!!!!!
Please Help Me!!!!
Regards
Dibdab
    Dell Inspiron 1520
    Intel Celeron M @ 1866 MHz
    Dell 0KY767
    1024 MB (2 x 512 DDR2-SDRAM)
    Mobile Intel (R) 965 Express Chipset Family
    82801H (ICH8 Family) HD Audio Controller
    Monitor Type : RP636154X3
    Current Display : 1280x800 pixels at 60 Hz in 65 536 colour
    Fujitsu 80GB
    Integrated
    Laptop
    Integrated
    Integrated
Hi
Please Help Me!!!!
Regards
Dibdab
Hi Dibdab, Welcome to the Forum.
Try this,
  1. Make sure that iTunes and the iPod Updater utility are not open.
  2. On your keyboard press Control-Alt-Delete. Select Start Task Manager.
  3. Click on the Processes tab.
  4. Locate the iPodService.exe in the list.
  5. Click on iPodService.exe and choose End Process.
  6. Quit the Task Manager.
Then try to uninstall Itunes
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
If the steps which Pooch provided won't help, download the Revo Uninstaller Portable | Portable USB Pen Drive Applications. It is the portable version of software that you will not have to install, unzip it to any location you want. With this tool you will be able to uninstall and get rid of any traces of the iTunes manually, just be very careful what you do.
Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Ok thanks very much guys I shall let you know how I get on :D
    Dell Inspiron 1520
    Dell 0KY767
    Fujitsu 80GB
    Integrated
    Laptop
    Integrated
    Integrated
Ok I have tried uninstalling it after ending the processes and still didnt work so gonna try one of the other options.
    Dell Inspiron 1520
    Dell 0KY767
    Fujitsu 80GB
    Integrated
    Laptop
    Integrated
    Integrated
Ok guys have finally managed to uninstall it with MyUninstall!!! Yay!!! Thankyou so much for your help.
    Dell Inspiron 1520
    Dell 0KY767
    Fujitsu 80GB
    Integrated
    Laptop
    Integrated
    Integrated
Cheers...
But these kinds of tools should not be used. It may damage your registry, this will lead u to a big problem:huh:
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
Cheers...
If you ever feel that these 3rd party tools can harm your computer, this is the best tool. Description of the Windows Installer CleanUp Utility
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Cheers...
Indeed, these application can harm registry, if one don't know what to do. That's why you can find there few uninstall modes like automatic, semi or manual. When you proceed with care in manual mode, you can get rid of all traces of software that was left by automatic one. ;)
Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
