keishaellis
I did a debugging and it said that my module_name: nwifi and image_name is nwifi.sys
can you help me fix ,my problem.
JK said:Enter msinfo32.exe into the start menu, and press enter. Go to File>Save, and save a copy on your desktop. Right-click on it, and select Send to>New compressed folder. Then attach the file to your next post.
[font=lucida console]
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Built by: 6001.22269.amd64fre.vistasp1_ldr.080917-1612
Debug session time: Sat Dec 4 13:40:07.552 2010 (UTC - 5:00)
System Uptime: 0 days 0:26:29.182
Probably caused by : CI.dll ( CI!I_MapCatalog+233 )
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
Debug session time: Fri Dec 3 21:07:51.180 2010 (UTC - 5:00)
System Uptime: 0 days 0:06:09.152
*** WARNING: Unable to verify timestamp for bcmwl664.sys
*** ERROR: Module load completed but symbols could not be loaded for bcmwl664.sys
Probably caused by : nwifi.sys ( nwifi!Pt6RepackRecvNBL+117 )
BUGCHECK_STR: 0xBE
Debug session time: Thu Dec 2 21:49:56.950 2010 (UTC - 5:00)
System Uptime: 0 days 0:00:21.574
Probably caused by : win32k.sys ( win32k!bCreateSection+330 )
BUGCHECK_STR: 0xD3
[/font]
