Problems with Disk drive
Kim Ryalls
So awhile ago I decided to update my Vista to Windows 7 but have come across a small problem every time I get to the boot up screen it just sits there loading the cd then when its done it does nothing. I thought it was just the CD but every CD someone burns for me it does the same where it will load up then sit there doing nothing.
system:
Acer
Aspire x1700
3.0 Windows Experience Index
Intel(R) Pentium(R) Dual CPU E2220 @2.40GHz 2.40GHz
2.00 GB
32-bit Operating System
thank you
if there are no cds in the drive what happens?
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Ok. Firstly have you made sure you have set the boot options in your BIOS to 1. CD/DVD drive 2. Hard Drive 3.USB ETC. It all depends on which ones in place 1. If its your Hard Drive then it will boot the hard drive leaving the cd. To enter BIOS, turn on your pc and when the logo comes up press F2 to enter bios. SOMETIMES its DELETE. When you are in bios navigate to boot. and depending on your bios use the designated keys to move CD/DVD drive to 1. if it is not there already.
Now try again.
2nd. Can you see it in my computer when you load windows?
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
You can also try turning on your computer, wait until it's fully started up then insert your Windows 7 installation disk and run it.
If that does not work then, it has to be a drive error. Test the drive with a DVD to ensure it can read discs.
    Sony Vaio/VGN-NS330J
    Pentium (R) Dual-Core CPU T4200 @ 2.00GHz
    4.00 GB
    4.00 GB
