Problems Upgrading to Vista Ultimate x64
al3408
When upgrading from XP Home SP2 and XP Pro 64 Bit either way I cant get it installed, not even from Vista Ultimate 32 bit. Tried first from 32 bit XP Home SP2 and figured the exe to run the setup from within windows was 64 Bit, so I tried upgrading from xp pro 64 bit and while the install does initiate it greys out the option to Upgrade and tells me I need to do a clean install.
I try that using the same upgrade disk, since it appears to give me that option, and after the initial setup steps when it goes to load the installation files it gave me a stop error 0x0000007b. I chose the "load driver" option and loaded the sata controller driver during setup and that took me past that error.
It goes on to go through the rest of the install then I get another blue screen 0x0000000A. I followed all the steps I could think of in Microsoft KB article 935806 with the exception of updating the BIOS and still no luck, since I really want to use that as a absolute last resort. Any Ideas outside of a BIOS update? That might fix it but I just want to make sure there isnt another known issue that anyone is aware of before updating it.
All my hardware is new:
Intel Core Duo 64 Bit processor
Asus Striker Extreme Mobo
4GB PC2 6400
Have you tried removing some ram, under certain situations vista will not install with 4g+ of ram installed
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
That's is exactly what I had to do and I have a Asus board as well. First use only 2 gigs of ram and boot into the Bios , there set your memory voltage and timings manualy. Then install the OS , after the install and when you have all your updates , install the other two gigs of ram and reboot.
    Q9450
    P5K Premium
    Corsair PC6400 DDR2
    Evga 8800 GTS 512
    Pri. - Seagate 500 32 mb Sec. WD 500 16mb and wd 250 16 mb
Have you got all 4gig in now?
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Nice one....it's easy when you know how lol ;)
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
