Problems to burn....
jaimetalmaster
Hi, i've just registered to this forums urging for help, i have a strange problem, i can read dvd's however, i can't burn dvd's, i've search for solutions but i've found none, hopefully i'll get one here.
I THOUGHT THE PROBLEM WOULD BE SOLVED WITH A SYSTEM RESTORE, STARTING FROM SCRATCH, I'VE TRIED ROXIO, NERO AND WINDOWS VISTA ITSELF TO BURN MY DVD NONE WITH SUCCESS
Which software are you trying to use to burn DVD's?
    Acer Aspire M7720
    Intel core i7 920 2.67ghz
    Acer FX58M
    6 gigs
    ATI Radeon HD4850
    RealTek HD
    Hanon 19"
    1024*968
    20mbit
Navigate to key HKLM\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and check you have phrases UpperFilters or LowerFilters -> if you find them remove them +restart
I've realized that the problem are the dvd's, i could burn with tdk dvd+rw but i can't burn with fujifilm dvd-r, what can i do with my 25 fuji dvds? Please don't tell me they're useless...
It is still not normal though. Appropriate firmware may fix it but I wouldn't fix anything when it is not broken. Keep the disks; you may get another drive down the road.
Cheers,
Bruce
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
