Problems installing civ 4 on vista
ajscndrl
Need help with the following-
I have installed civ 4 with the warlords expansion pack on my vista home edition premium 6.0. Install went smoothly.
When trying to launch the game i get this error message: This application has failed to start because D3DX9_32.DLL was not found. Re-installing the applicatio n may fix the problem.
I have tried re-installing with no luck.
Microsoft then tells me that the problem is with directx 9 and gives me a link to update the end user run-time installer. Which sounds like a perfect and easy fix.
Turns out that no matter what version or update i try to install I am screwed. I get this error message upon the initializing phase of the install: An internal system error occured: Please refer to the dx.error log or the Dx.log in your windows folder.
As i said it does not matter what version of directx i try to update i get the same message. Can I not play Civ 4 on vista? I have heard maybe the compatibility mode might fix but I am unsure how exactly to do that right. I have tried a few times...Also spent hours on the phone with game support and microsoft support and they have no answers?
Can anyone please help me this is my only computer!!!
Thanks-Alex
Thanks for replying but i have tried installing the latest web installer and i get an error message "An internal system error occured: Please refer to the dx.error log or the Dx.log in your windows folder."
Doesn't matter what version i try to install i get the same message. And I have looked at the logs and it says there are no issues.
I'm stumped :(
google D3DX9_32 and there are sites you can download the dll from.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Once i have the dll downloaded do i need to run that application somehow
As of right now it has made no difference in ability to play the game thanks
put it in your system32 folder
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
