Problems after Update KB981793
longojim
Since installing (KB981793) update to Vista on June 26th I have been having a few problems. (1) Security update for Office 2007 Powerpoint (KB982158) fails to install - returning error code 8007066F. (2) My financial software Quicken 2009 and now 2010 fails to start - "Quicken Launcher has stopped working". I am running Vista Home Premium SP2. Any ideas? (This is my first post; hope I did this correctly.)
    Acer M1100
    AMD Athlon 64X2 Dual Core 4400+ 2.3 GHz
Hello longojim,
Welcome to Vista Forums.
First try removing the update.
Here is a tutorial on how to do so:
http://www.vistax64.com/tutorials/92402-windows-update-uninstall.html
Before re-installing the update, do the following:
Press the Windows Key + R
In the Run Command type: msconfig
Click the "Services" tab
Check the box entitled "Hide all Microsoft Services"
Click "Disable all"
Click "Apply"
Click " Ok"
Restart your computer and re-install the update.
After you install the update and are prompted to restart, I would suggest restarting one more time.
You can re-enable the services using the same method.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
I think the only solution for you is reinstall Office,if you have any problems with uninstalling this use "MS Fix it" from this site:How do I uninstall the 2007 Office suites if I cannot uninstall it by using the "Add or Remove Programs" feature?
I too have had the same problem with Vista 32 bit Home Pre + Service Pack 2.
I was directed to and did, turn off the User Account Manager in the control panel. Rebooted and ran the update.
After that I turned the User Account back on, rebooted and now the Windows Update program says my computer is, Up to Date but there was a failed attempt to load a update.
I have spent way too much time on this... T hink I am happy right now but;
In the process I tried to log on to MircoSoft and give them my product key in order to ask for help. I got a response that there was something wrong with my product number.
That confuses me just as bad as the update situation before. I would hate to pay them $50 just to find out it was a stupid error and I too am wondering if I now need to update to Windows 7.
    HP Pravillion dv2815nr
