Problem with sound -Need help-
sleepingdragon
Hey everyone,
I just recently formatted and reinstalled Vista because i changed my motherbored and Processor so i felt like a new start.
After waiting for all the Windows updates to finish i turned on some music and my Sound was messed up, i have sound it just dosn't seem to work right.
On some ill be able to hear everything but the singer and on others and hear only the singer.
This also effects games, i turn on my scarface seeing it was closest game near me and installed it, on that i can't hear Scarfaces voice, or the cars around me but i can hear other people speak.
Does anyone know whats wrong with my sound?
I use the soundcard that is built onto my motherbored because i have never had need of a Sound card in the past.
my new motherbored is an MSI motherbored and my processor is Intel core 2 duo
System Model: MS-7383
Processor: Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz, 2336 Mhz, 2 Core(s), 2 Logical Processor(s)
Sound & Video drivers is something I don't let Windows Update install, I usually do those manually because of problems like the one you are describing.
If you go to one of the Stickied posts you'll see a thread on the Latest sound drivers for Realtek, I am assuming those are the ones you are using since they usually come with onboard sound, if not... find the mfg of your sound card and download their latest drivers for the OS you are using, download it to a folder you can later find.
Go to Device Manager/Sound/Driver and uninstall the drivers you have at this moment, reboot if asked.
After you are back at the desktop, find the file you just downloaded and run it, remember to do so as "Run as Administrator"... righ clicking on the file should give you this option.
Once you are done, reboot for good measure, once at the desktop, unplug the sound cable(s) and plug them back in one by one and look for the Realtek Audio Manager to appear telling you that you just plugged a cable, making sure you answer the questions correctly.
This may help
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I did some research on my bored and it is Realtek, but everytime i goto the site to download, i click agree, allow cookies from the site but when i click one of the 4 options to download from this error appears
Is there another place i can download Realtek from?
You are trying to download from a secure FTP, just choose download from Site 1, 2 or 3 and NOT from Express.
You are going to have to patient as those 3 site are very "s l o w"
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
I tried from all these, and the express one they all do the same thing, only each one trys to connect to a diffrent ip.
Also on that page nothing loads, it just sits there and on bottem left it says done, so nothing else is loading :confused:
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
Realtech audio drivers
Download Realtek audio card drivers
I assume you have downloaded and installed all your latest motherboard drivers also?
Yes i have the latest motherboard drivers.
I also don't really like useing things like that (driver detective) something about it dosn't look trustworthy, and i have really no need for it because am only haveing problems with my sound, thanks anyway though.
Am gona check the MSI site which i proberbly should have done at the start, but as it being a sound problem it didn't really occur to me to even check it.
Okey so i searched for my motherboard and came across some Drivers for "Realtek High Definition Audio Driver" and downloaded them, when it was completed i retarded the PC, unplugged my speakers and plugged them back in and that Realtek HD Audio manager came up, i tested some music, and no change the sound is still strange and distorted in a way.
If the actual drivers don't work, how am i supose to fix this issue.
Well i thought id get an old sound card i had and put it in, On the front it says Speedlink, thats all i know about it.
When i installed it and put in the drivers, retarted PC, unplugged and plugged in my speakers and the exact same problem, i have sound like before but it is still really distorted some sounds are missing and on some games i can only hear certain things.
I don't know what is wrong with it now that i have installed Realtek drivers, plus put in a sound card, which both give the same result.
Maybe i should just plug in my old motherboard which i really don't want to seeing as it only holds 2 RAM chips -.-
ACK sorry didn't even realize that was that "driver detective" site, yeah I wouldn't download that either.
You might be so mucked up at this point that it might be better to just reformat and start over making sure that you know exactly what drivers etc you need to install before you start then just systematically go through it.
Make sure to check your BIOS also to see that it is set correctly for whatever sound card/chip you are running.
    Home Built
    Q6600 @ 2.66ghz
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Cooler Master 750W
BE advised, the Realtek site SUCKS Big Donkey Ba, erm, well... you know! ;) but it is the only site I would trust downloading the drivers from.
Either that or maybe Download.com... if they already have the newer drivers posted.
If you can't get them, let me know and I will upload them to Rapidshare.com and you can download them from there.
I can only promise you that I run Avast on everything I download and I did so from the Realtek site so it shouldn't contain any viruses or pesky worms.
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
Aha, well first off let me thank you guys for all your help.
You guys were great, and you also aint going to believe how i got it to work.
I was actully took Nunya's suggestion of reformat and reinstalling everything, which i did and when i finally tested the sound i was shocked that it was still broke.
I just got fed up and went out for awhile and came back with a friend of mine, we came back to play lineage2, when it just came to be that before i changed my motherboard and stuff that the wire that connects from the speakers to the back of the PC was someway broke and if you didn't bend the wire to the side it made the sound disapear but on this motherboard it just distorted the sound, well when i bent the wire the sound was fixed everything fine dandy and bloody normal.
I nearly jumped out the window xD
thanks again guys who would have thought it would just require me to bend the wire for it to work :shock:
