Problem with software downloads
POPPYJIM2
Can't download software ..when I download and open I get an error saying (Another installation is in progress you must complete that installation before continuing this one .. I can't find any other program being installed !!! Is there a way to clear the windows installer ??? thanks
It means another installer hasn't finished intalling, have you tried restarting your computer.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
MANSRM81 Thanks for the reply, yes I have restarted a bunch of times can't find anything that is even remotely close to installing..I have even went back a week and did a system restore.. I am at my wits end....
Have you looked at the task manager and see if there is anything unusual running that shouldn't be, Have you scanned for viruses and spyware. Also go into the control panel/ administrative tools then event viewer and see if there are any errors.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Mansrm81 Like to think you for answering my questions..Just for your information I found the fix for the stuck windows installer,Just in case you run into it again...guess it is quite common in vista if your downloading and for some reason stop and cancel the download..The installer sometimes doesn't release it from the registry...here goes:
Error 1500. Another installation is in progress. You must complete that installation before continuing.
When you click Retry , the message displays again. If you click Cancel , the installation stops.
Use the following steps to fix the problem.
  1. Cancel the software installation and remove any discs from the computer.
  2. Press Ctrl + Shift + Esc to open Task Manager.
  3. Click the Services tab .
  4. Right-click msiserver and select Stop Service .
  5. Run the software installation again.
Again I thank you for your efforts Resp't / PoppyJim ;)
Glad you found out what you had to do nice work.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
North 100 miles south west of Chicago.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
