HI,
I have a problem I am hoping can be solved here. I have a vista pc with the NAS attached to the router. The installation went well and from the Vista Pc i was able to see my NAS. However neither my mac nor the PC were able to see each other although I could see the NAS on my Mac using Finder. I researched the topic and located a tip that I thought could help. The tip said to go into regedit and locate the lek Hkey_local_machine\system\Current Control Set\Control\LSA and change the value from what I had which was a 3 to a 1. I did so and rebooted. when I went into Network I could see the in the upper part of the screen the modem one of my wireless printer the pc. In the lower part of the screen was the NAS and my other wireless printer. To the right of the screen was a message indicating what to do if not my network was not showing properly. I went into windows explorer and I could not see the NAS or the wireless printer. I then went into regedit and reverse the change I had previously made and rebooted.
When I went back into Network the same screen as before appeared. In Explorer I could not see the NAS. I then tried several system restores and none of them work. I am at a complete loss as to what I should do. next Can anyone help?
Carl
Carl
