Problem with media player
mazdaclaes
Hello
I'm having a problem with playing movies and videos on every media player that i have on my computer, what can be the problem? And what can I do to fix it?
Hi Mazdaclaes,
Welcome to Vista Forums!
Do you know when this problem began? Try a System Restore to a point in time BEFORE the problem began. Here's the procedure: http://www.vistax64.com/tutorials/76905-system-restore-how.html. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed between now and the restore point, but you can use Windows Update for the updates.
I hope this helps.
Good luck!
    1920 x 1200 pixels
