Problem with IE
r6biker
My IE has some how been corrupted and now will not work no matter what i do, is there a way i can delete it and re install it? I have admin access and it still would not let me delete ie from my pc?
Thanks
    Intel Quad q6600 2.4ghz 8mb
    PCI Express SLI nForce 650iSLI(C55) INTEL CORE 2
    256MB NVIDIA GEFORCE 8600GT
Thanks
Questions first;
  • Which version of IE are you using?
  • Have you tried to do a System Restore to an earlier point before the instability issue?
  • Have you tried to go to Start>Control Panel>[Classic View] Programs and Features>Windows Live Essentials, and either tried to carry out a Repair or Uninstall from there? [just select your choice of radio button, and follow the prompts]
  • What Anti-Spyware/ Anti-Malware/ Anti-Virus scans have you done?
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
In addition to what sassfalco suggested, you could try resetting IE as well. Tools-> Internet Options-> Advanced tab and reset.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
It can be turned off and replaced with another broswer of your choice, eg, chrome or FF.
To turn off type turn window features on and off. You will then be able to uncheck IE 8. If you decide on this option be sure to have another browser or you will have to turn it back on to download the browser of your choice.
Guys
Thank you very much did what you all said and it worked!
Thanks again
Good for you, rcbiker. Take care.
Guys
Thanks again
Great to see that all worked out fine r6biker.
As a matter of interest, did you give Firefox a try? If you have installed it as an alternative browser, I have a great guide, without peer, for installation and set-up. I used it in my set-up, and for the past 15 months, not one freeze or crash!
Come back if you're interested and I'll post the link.
And don't forget that this Forum has a wealth of self-help material, and some excellent, patient advisers who are always ready and willing to help.
See you around
