Problem with Hard drive!
fields999
Hey
I was just looking on my hard drive and i noticed that it says 256gb free for 451gb
Im not sure why this is because all my files including the hidden files and everything, comes to 112GB only and its telling me i have 200gb of used space when i dont.
Does anyone know why this is happening? Ive cleared the recycle bin aswell but still cant see what the problem is.
thanks
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
Disable System Restore to recover space.
    16GB DDR667
    SAS RAID
Oh its because its making backups?
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
Yes. System restore does tend to chew up space. I would leave it on. You have 256GB free. Add another hard drive and move your applications and data to it. You can get a 7200.11 500GB 32MB drive for $80.
    16GB DDR667
    SAS RAID
Is there a maximum amount of space it will use or does it just make a copy of the contents of my hard drive, so just doubling the space used?
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
It can make multiple copies for system restore because you roll back to many dates. You can disable system restore to clear all restore points. Reboot. Turn it back on and create new restore points. Every time you add something new, it creates a new restore point. Unless you are really chewing up disk space, don't worry about it. You are better off with many restore points.
    16GB DDR667
    SAS RAID
you can download and install windirstat. it will tell you specifically what files are in your installation as well as how large the files are. it gives a graphical display of those files, as well, so you can really see what files are in your installation and the size of them. the larger the block, the bigger the file.
the first pic shows the program querying your system and the second pic shows the graphical representation of the files. i have team fortress 2 content.gcf highlighted and there is a white square on the bottom that corresponds to the size of that file within files>steamapps>steam>program files (x86)>windows(c)
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
dont disable it it will get you out the sh!t one day ;)
Agree with archie123 ;)
Disabling System Restore is only asking for trouble, especially if you need to roll back to an earlier state because something went crazy with your system.
I've left mine as is, but I have plenty of hard drive space.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
