Problem with CoD WaW
Rhyno1
Hey, i was wondering if you guys could help me with an issue that i have with my newly bought CoD WaW game. I bought it from steam, so that may be where the isses lies, i have tried to re-install it several times though. The game runs flawlessly, but every 30, 40 seconds the game freezes for about 8 seconds. Also, the cinematics are all blackened, but the sound is still there. Hope someone here can help me with this, thanks in advance :).
The problem with freezing every 8 seconds I have seen happen for 2 reasons that i can think of.
1) on a laptop this can be caused by not setting the power saving mode to high performance, If it is set to power saver, (by default) it will throttle back the processor to save power even if you are plugged in. You have to set it to high performance.
2) on PC's I have seen it when a usb hub is plugged into a machine and a mouse is hooked into it, everytime you move the mouse it will slow down the video because it is robbing cpu cycles every 1/1000th of a second to scan where the mouse position is or something. If you unplug the hub and just plug the mouse into the machine this stops. Sometimes I can get it to happen with keyboards as well. The one hub that did this was a belkin hub.
As for the multimedia problem, that sounds like an incorrct video driver issue, or not having the motherboard chipset drivers installed.
hope that helps, if I think of anything else Ill post you back
-K
    Dell vostro 1500
    core duo 1.6
    4gb + 1gb turbocache
    8600m GT 256mb
    Onboard Sigmatel
Providing your system specs can yield better or, at least, more answers. The more info you provide, the better we can help. Stating the Driver versions of your GPU & Audio is always a plus because when people say their drivers are up to date, the majority think that by installing the drivers that came with the CD they are up to date and they can not be further from the truth.
USB mouse is one of the culprits as stated by Klaudius. Below minimum system requirements is another one, old video and audio drivers could cause problems as well.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Hey guys, i dont have any hub connected and i'm using a pc.
Below are my pc specs.
Windows Vista™ Home Premium Service Pack 1
Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz (2 CPUs), ~2.7GHz
3070MB RAM
DirectX 10
NVIDIA GeForce 8600 GT
Not sure if you need to know somethings else, if you do ill be happy to post it.
Thanks in advance :)
Can you check what your Video & Audio drivers version are?
Is your mouse wired or wireless, what brand and model?
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
