problem with browsers and virus
scorp200
hey yesterday every thing was ok
and suddenly when i started mmo game
the security of the game said there is an abnormal memory access
then i notice that on the game launcher where it should show webpage
it not loading and when i click there is make sound like its busy
same thing on IE, after that when i opened firefox some why firefox close it self
even in safe mode but the process still running, i started virus scanning with norton 360 and male ware scanning with maleware bytes, and it didnt find any thing
besides that every thing else seem sto work fine
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    Hitachi HDT721010SLA360 ATA Device 1TB Hitachi HDT725032VLA360 ATA Device 320GB WDC WD2000JB-00GVA0 ATA Device 186GB
    550w
    logitech G5
    microsoft
    12MB
Show us your running tasks.
MSINFO32
Please go to Start and type in "msinfo32.exe" (without the quotes) and press Enter
Save the report as an .nfo file, then zip up the .nfo file and upload/attach the .zip file with your next post.
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock Synaptics Pointing Device
    stock
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246 I like chocolate milk!
Take the sage advice of pauliewalnuts and in addition take a memory diagnostics, to see how the memory is working. Just type memory diagnostics in search and click to begin the test.
Run and A/V scan
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    550w
    logitech G5
    microsoft
    12MB
i wrote in the first post that a did all of that
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    550w
    logitech G5
    microsoft
    12MB
Your homepage may have been changed, go to the hompage icon and see what is listed as your homepage. If you change it back, does it return to the page that you do not want?
I understand that you mentioned that you did a virus scan, but this does sound like something that has gotten into the system and causing problems.
As I thought, I have come up with a possible reason for your problem, you may have been scripted.
Go to internet options and home page. Is it your home page?
Then go to browsing history and delete.
then go to settings, view objects, delete all scripts and program applets
Make a system restore before you begin, in case you do not like the results.
This should work
What he says and, dude, upgrade Vista. You're on SP1.
There's exploitation pipelines in SP1 galore.
    stock 1280 X 800
    stock
    stock
    stock
wow all the time i thought i did update to sp2
edit:
i reinstalled sp2 and IE8, seems that Ie work fine but i still have that problem
with the abnormal memory access
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    550w
    logitech G5
    microsoft
    12MB
i was deleting reinstalling and every thing i know
and i think i found the source of the problem,
i think its java because java intergrades with IE and firefox
and when i tried to disable java in firefox the firefox crashed
edit:
it didnt work IE work fine now but firefox still crash
and the mmo game security saying i have abnormal memory access
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    550w
    logitech G5
    microsoft
    12MB
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    550w
    logitech G5
    microsoft
    12MB
Does your Rockstar Games Social Club crash, too?
I'm wondering if it's a .NET error. A .NET framework error would explain why it's only Internet applications that are crashing.
Go to your "Control Panel," to "Programs and Features," then Uninstall any Microsoft NET framework version you have.
Restart.
Go to Download .NET Framework 3.5 SP1 and More on MSDN and download the 3.5 Service Pack 1. Install it and restart and see if your programs work.
    stock 1280 X 800
    stock
    stock
    stock
No it's really a root kit virus.
Norton finally found it and deleted
    intel core 2 duo
    msi
    2gb
    geforce 9800gt
    lg L1953TR
    550w
    logitech G5
    microsoft
    12MB
Sweet. Myth busted.
    stock 1280 X 800
    stock
    stock
    stock
