Problem with Age of Empires 2
AndrewPMS1234
Hi
I am new to this forum, i just recently upgraded to Windows vista x64 and i installed my favourite game on it, it did not work.
After installing the game at end of the installation, it errored and said there was a graphics problem, this is before the game even ran, cos i tried installing it on wondows xp 32 bit and at end of install on the winxp 32 bit, it brings up the graphics autorun menu from the cd, so i presume that is a problem bringing up the autorun menu after install completes.
Please help
  • Graphics card(s)
    ASUS GeForce 8500GT (256 Mem 500x2) (475 Mhz GPU)
    ViewSonic VA2016w (LCD 20in, 16x10 ratio, 0.25 Dot Pitch
    1680 x 1050
    Samsung HD5021J (500 Gig, Sata 2)
    300 Watt Continous (350 Watt Max)
    Trust AMI Dual Scroll 300
    Trust Direct Access II Keyboard
    ADSL2 (Upto 24 Meg) Connected at 11 Meg (3.8k from exchange)
    Multi Media PC, Blue Ray Drive ASUS BC-06B1ST
Hello AndrewPMS1234,
First of all, are your drivers up to date ?.
Go to the Nvidia site and check.
It is possible to get this running on Vista x64 but it's not easy and no guarantees, some people have got it running and some cant get it to go at all.
1. Install the game, (as administrator).
2. Carry out any updates/patch's.
3. Ensure AOE 2 .exe is running in windows xp compatibility mode and as administrator. (right click exe in game folder, click, properties, compatibility, and run as administrator).
4. Ensure you have access to the install folder. right click – security – edit – select users – check full control.
5. If you have Aero running on the desktop, turn it off.
Give this a try and post your results, good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
