Problem while installing software !!
finger
PLEASEEEEEE HELPP !!!
i want to install the program nokia software updater, but each time i try to install it this message appears " This instruction at 0x00200065 refrenced memory at 0x00200065. The memory could not be read. Click ok to terminate the program"
and it stops the installation.
i tried to install other programs and they were installed.
i also installed the same program previously 2 months ago, and it was working, i don't know what went wrong.
i also installed it on another computer and it worked!!!
PLEASEEEEEEEE HELP !!
Is the Nokia app written for Vista ? ?
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Hi finger,
Try running SFC and checkdisk. Are you installing it as an administrator? Try that if you have not and try compatibility mode and putting it in the DEP allow list before trying to install it.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html?ltr=S
http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html
http://www.vistax64.com/tutorials/75909-compatibility-mode.html
http://www.vistax64.com/tutorials/65790-dep-turn-off-programs.html?ltr=D
Some suggestions that might work, might not. Post back and let us know.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
