Problem| Vista isn't showing my actual cpu speed!
lordik
Hello, i am owning vista ultimate x64. with core 2 duo e8400 3GHz & 2.83 GHZ.
always, when i was checking the computer properties i saw this written: intel core 2 duo e8400 3GHz & 2.83 GHZ.
anyway, last night i made an overlcock from 2.83 ghz to 3.2 ghz, when i entered after the OC to the computer properties i saw that the computer has changed to 3GHZ & 3.2GHz.
then i set the cpu speed back to the normal speed (normal fsb) and then when i checked system properties i saw 3GHz & 2.66 GHz.
it was really strange because cpu-z and other programs showed me that i am using 2.83 ghz and not 2.66.
anyway, i tried to fix it and i did again overclock to 3.2 ghz.
but then, when i started the computer again and clicked on system properties, i saw still Intel core 2 duo e8400 3GHz & 2.66 GHZ, but cpu-z and some other programs showed me that i have 3200 mhz.
so my question is this:
why vista is not showing my actual bus speed and cpu speed and it's showing wrong cpu speed.
my second question is:
even if the cpu's speed is not written on the computer properties, as long as it's written on cpu-z and other programs that i have 3200 mhz, the computer will use it, right? or it will use just the 2.66 ghz that is written on vista?
sorry for my poor english, hope you will answer me :cry:
Yours,
Roy.:huh:
    Intel Core 2 Duo 38400 3.0Ghz 6MB Cache S775 1333Mhz
    EP45C-DS3R
    Kingston HyperX 2x2GB DDR2 1066Mhz PC2-8500
    Gigabyte 9600GT 512MB GDDR3 DX10 HDTV 2XDVI PCI-E
    Arctic Cooling Alpine 7 Pro CPU Fan For s775
I shouldn't worry too much about it..Vista's not that accurate in these things...I'd rely on the CPU-Z numbers....
....and look in the bios - that should tell you the real speed too. Just to check.
    system1 (system2)
    q9650 3ghz (i7 920)
    Asus p5q deluxe (p6t deluxe)
    16gb ddr2 (12gb ddr3)
    Nvidia 8800GTS 640mb (285gtx 1gb)
    on board
    Eizo CG301w, Dell 2407
    2560 x 1600 + 1920 x1200
    Raptor 74gb, Raptor 150gb, 500gb x2, 320gb, 750gb (raptor 150gb, 2x 500gb)
    ocz 600w (ocz750w)
    coolermaster stacker (coolermaster 690)
    many fans
    intellimouse
    apple slim aluminum jobbie
    2mb
    Wacom A3 tablet, Epson 3800
Might be useful to us if you filled out your system specs so we can better help you.
Also screen shots might help to, ones that show cpu-z and what Vista System says.
I know mine says:
Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz 2.50GHz
2.50GHz - What it is set at now...
2.50GHz - What the CPU is defalt
When I have it OCed it looks like this:
Intel(R) Core(TM)2 Quad CPU Q9300 @ 3.0GHz 2.50GHz
    RemnanteK
    Q9300 3.0Ghz @ 1.175v Stable
    EVGA 780i
    4x1GB Corsair Dominator DDR2-8500 (5-5-5-15 :1067)
    EVGA 8800GT 1Gb Akimbo
    Onboard 7.1
    DELL 2005FPW
    1650x1080
    2x 750Gb Seagate SATA 1x 1Tb Seagate SATA 1x 250Gb Seagate SATA
    ABS Tagan BZ 700W
    Cooler Master Cosmos 1000
    Zalman 9700 // CORSAIR CMXAF1 Fans
    MS Explorer 3.0
    MS Ergo 4000
    12MB
Well, something is definately iffy there. According to Intel, your CPU is rated at 3.0 Ghz so it should read E8400 @3.0Ghz 3.0Ghz and not @3.0Ghz 2.83Ghz.
I would go to the Bios, set everything to Default, clear Cmos and start the PC to see if vista then recognize it correctly. If it does, reboot again, get to the Bios and change your set up to how you had it before, sans the 2.83Ghz iffy part ;)
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Hey,, I updated my info on the site (my cpu etc...)
here is the exactly story of how it has started:
i had normal system settings (no OC) and when clicked on system properties i could have seen this:
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00Ghz 2.83Ghz
Then, i overclocked it to 3.23Ghz and when i click on the system properties i saw:
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00Ghz 3.23Ghz
then i got back to original cpu speed (no OC) and when i click on system properties i saw:
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00Ghz 2.63Ghz
So, it looked a little bit strange to me and then i tried again to overclock it on bios to 3.23Ghz and after i Overclocked it i opened system properties and i saw:
So, i think something is wrong here! because that is was vista is showing my and cpu-z and other programs are showing me the speed i have chosen (3.23Ghz)
here is a pic:
    EP45C-DS3R
i think the stock multi for an 8400 is x9..?? yet cpuz is showing x8.5
have you disable EIST & CIE support in the BIOS..??
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
i couldn't find EIST but i have found C1E and disabled it...
but i don't think that is the issue, the issue is that it should write to me that it's using 2.67Ghz when i am using 3.2...
    EP45C-DS3R
:)SK
yes! you were right! i changed the bios settings instead of x8 and x0.5 to x9 and now it is showing the correct speed at vista! thanks!
    EP45C-DS3R
glad you got it sorted......;)
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
but this is fuc**** annyoing!
now it's showing me intel e8400 3GHZ 3GHZ but when i tried to overclocked it to 3.4GHZ with multi of x9 it's still showing at vista 3GHZ 3GHZ and not 3GHZ 3.4GHZ
why is that?!
    EP45C-DS3R
why is that?!
vista will only EVER work off the default multi, if you OC your chip you cant use the vista system information b/c its not built for the change...;)
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
