Problem unzipping MS Office in Vista 64 bit system
windvista
I have a new Dell Studio XPS computer. Sometime after purchasing I recently had to reinstall Vista because of serious internet connectivity problems. Since then I've downloaded a fully licensed Office 2007 from my university's website-used it before on XP and it worked fine. On XP options for unzipping the file is possible but in Vista I don't get the "Extract All" option when I right click. Instead when I select "Open" which is my only option, I get a message that says "msoffice.exe is not a valid Win32application." I don't have problems unzipping other files.
    dell studio xps
Re: Problem unzipping MSoffice in Vista 64 bit system
windvista,
Use another Compression Manager like 7Zip or Winrar, both have x64bit versions. If still same problem, then your download file could be corrupted while downloading, which if it is, then you would need to download it again. You can pick up the 7Zip x64 Here, Plus a few other x64 Goodies while your at it.
Code:
http://www.start64.com/index.php?option=com_content&task=blogcategory&id=0&Itemid=55
Good Luck Friend.
Marine43
    Dell XPS 430
    Intel Core2 Quad Q8300 @250GHz x 4
    Dell - OG254H - AOO
    Hyundai - DDR3 PC3 8500F - 533MHz (DDR3 1066) = 6GB RAM
    ATI Radeon HD 3600 Series w/ Built on Processor & Fan
    IDT High Definition Audio & ATI Function Driver for High Def
    22" Dell S2009W Digital Monitor
    1600x900
    750GB 3 Partitioned Drive. - Seagate. ST3750630AS - Six - USB 2.0 Slots - Internal - 12 in 1 Card Reader - Internal - TEAK FD-05PUB External Floppy Drive -
    Dell Optical Laser with Speed Controls
    Saitek Illuminated Gaming Keyboard
    82566DC- 2 Gigabyte Network Connection - 16MBps
    Hauppauge Win T.V. HVR-1250 - Digital Tuner Card - Conexant D850 PCI V.92 Dial Up Modem - HL-DT ST DVD + -RW GH30N - Dual Layer/Blu-Ray Capable - Epson NX100 Series - Printer, Copier, Scanner - Dell Desktop Stereo Speakers
