Problem running games
CRPishere
Hi all
I just upgraded an older computer to vista 32bit home premium and the upgrade went well. This computer is used mostly for satellite tracking and is running all of the necessary software just fine, including some DOS apps. I also use it for running the few games that I like, all racing sims.
F1 2002, F1 2007, F1 2008 and TOCA race driver 3. Not one of these games will run no matter what I try. I've updated all the video drivers, set the compatibility, run in administrator mode and anything else I can think of. Once started the games run their video check programs and the screen goes black and that''s it. I have to do a power switch reset to get the computer back. These games all ran great under xp on the same machine.
I would prefer to get the games working in Vista, I find it much more user friendly than xp but if no solution can be found for this problem I will have to go back to xp.
Which brings another question, will I be able to revert to xp using the OEM disk that came with the computer?
Any help on these issues would be appreciated.
Charlie
Well no help here. Sad that my post was moved from the general discussion area because I feel I had a better chance over there. Mostly youngsters here I guess.
Anyway I went back to xp and set up a dual boot system.
Did any of those games asked you to install DX9? and if so... did you?
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I wasn't aware you could buy F12007 and 2008 for PC. Is it an update to EA Sports F1 Challenge?
    Intel Core 2 Duo Quad Q8200
    4Gb DDR2
    nVIDIA GeForce 9800GT 512MB DDR3
    500Gb
