Problem Reports and Solutions
MajorOwl
Can anyone tell me what the log file name is for all the problems reported? I am about to re-image a Toshiba, but want to print out the problems that were identified for the customer to see.
There area number of incompatible devices that have been used which have obviously de-stabilised the OP SYS.
Start>Run>WERCON
Cheers..
    Compaq Presario C700
    Intel Core 2 Duo 1.67 GHz
    Intel GM965
    2.5 GB (2 GB Transcend + 512MB Hyundai)
    Intel Intergrated 965 Express Graphics
    Conexant High Definition
    Compaq
    160 GB Compaq
    Alps Pointing Device Touchpad
    Compaq
    2 Mbps Download, 512 Kbps Upload
    Integrated Web-Camera (P.S. Have another custom-built PC with Win7 x64)
Thanks but I didn't mean to view the log file I want to copy the actual log file name and the print it out.
WERCON just displays it on the screen as though you had accessed it through:
\Control Panel\Problem Reports and Solutions...
Any other thoughts?
Sorry :D, but if thats the case then do the following-
Open up run, type in "eventvwr.msc" which opens up the event viewer and then you can copy and paste the log and print it out;
OR
  1. Click the Start button.
  2. Click Control Panel.
  3. Click System and Maintenance.
  4. Click Administrative Tools.
  5. Double-click Event Viewer.
    Intel GM965
    Compaq
    160 GB Compaq
    Compaq
Well I think I got there using your first method (Start>Run>eventvwr.msc) but couldn't work the other.
Do you know whether there is just a file in the \System32(?)folder or similar that has this information (or perhaps it is stored in a fairly unreadable format)?
The first method looks like I have the correct place but the data doesn't look the same as the \Control Panel\Problem Reports and Solutions\View Problem History....
which shows you: Product, Problem, Date and Status.
Anyway I have paged my way through the history and Ctrl+Alt+PrtScn each page and put it into a WordPad document which is okay - thanks for your help.
Welcome, Happy to help..
Cheers..
    Intel GM965
    Compaq
    160 GB Compaq
    Compaq
