Hi:
Just installed vista x64 SP1 with all latest updates, installed latest Shark codecs and K-lite codecs.
Have no problem playing video files in Media player, but the same video files are not properly played in Media Center. They blink from time to time. It looks like a problem with codec, but after installing Shark and K-lite codec packs the problem still the same.
May be Media center gets different codec. How do I change it?
Any idea?
My second question is:
How do you add extra programs to Media center in vista x64?
In XP MCE 2005 you could just drag desired program to the start button and prop it there and it would end up in MCE.
It doesn't allow to the same in Vista MCE.
If you drag the program to start button it will open MCE, but you won't find the added program in MCE.
Could you help?
Thanks!!!!!!!!!!!!!
Any idea?
Could you help?
Thanks!!!!!!!!!!!!!
- Intel Core Duo 2 6600 @ 2.4 Ghz
- Asus P5W HD Delux
- 4 GB DDR2 (Consair)
- Asus GF 7600 (256MB) HDMI (NVIDIA GeForce 7600)
- on board Realthech
- Visio 42'' LCD
- 1920X1080
- x2 Samsung SATA - 500 GB x2 WD SATA - 1 TB
- PSU
- Zalman
- Case
- Zalman HD 135
- Cooling
- Zalman
- Logitech diNovo Mini
- Cable
