Problem in Gaming
AlexRD
I have a problem that really bothers me.
It is a game problem, when i'm playing a game,
after like 3 minutes it starts to bug, like if the framerate was really low.
The game i'm playing is LineAge II ( Good Graphics though ) and it is online.
I don't think it is a network problem, because if it was it wouldn't
run smoothly the first 3 minutes. I'm running x64 Architecture.
Edit: If i shut the game down, and wait for like 1 minute and play again the problem goes away and i have 3 minutes to play ( Lol )
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    Asus G2s Keyboard from Logitech
    2 MB Wireless Network
Hopefully your 8600M has a temp sensor on it. Grab this,
GPU-Z Video card GPU Information Utility
run it and click on the Sensor tab, if there is a temp sensor it should report it. If so put a check in "Log to file", then run your game. Once it starts slowing down check the log and post back what the highest temp was; also what it is/was before running the game (idle).
If it is what I think it is that is happeneing, the only way to fix it will be to contact Asus about an RMA. In case you don't know what I am referring too,
http://www.techcrunchit.com/2008/07/10/nvidia-tries-to-cover-up-defective-gpus/
and yours is one of those.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Nvidia Tries To Cover Up Defective GPUs
Damn it, i think you're right.
Now, without playing anything its 98C.
I'm going to have to send my notebook to asus again. =(
    Asus G2s
    17" Generic PnP
    1440x1280
