Problem after installing SP2 on Vista x64.
Buddy Kidd
I can reboot all day long with no problems but when I do a shut down I will often get a BSOD with Stop: 0x0000007E. The only way I can get the computer to boot up is to do a system restore from the Vista install disk. Of course I am then back to SP1.
Does anyone have a idea what could be causing this?
    Intel i7 920
    Asus Rampage II Extreme
    6GB DDR3
    Asus EAH4870DK
    View Sonic
    Raid 10
    Air
    Logitech Bluetooth
    Logitech Bluetooth
    10 MB
You may receive a "Stop 0x0000007E" error message after you enable the BitLocker Drive Encryption feature in Windows Vista
After you enable the BitLocker Drive Encryption feature in Windows Vista, you may receive a "Stop 0x0000007E" error message that resembles the following: STOP 0x0000007E (parameter1, parameter2, parameter3, parameter4)
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Back to the top
CAUSEThe problem may occur when certain drivers, such as a chipset driver, are insta...
The problem may occur when certain drivers, such as a chipset driver, are installed on the computer before you enable the BitLocker Drive Encryption feature. Back to the top
RESOLUTIONService pack information To resolve this problem, obtain the latest service pac...
To resolve this problem, obtain the latest service pack for Windows Vista. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 935791 (How to obtain the latest Windows Vista service pack ) How to obtain the latest Windows Vista service pack
Back to the top
Hotfix information
To resolve this issue, install the hotfix that is described in KB 929637.
For more information, click the following article number to view the article in the Microsoft Knowledge Base: 929637 (Error message during Windows Vista startup if the Nero InCD program is installed and if the "Special pool" feature is enabled in the Driver Verifier utility: "Stop 00000050" ) Error message during Windows Vista startup if the Nero InCD program is installed and if the "Special pool" feature is enabled in the Driver Verifier utility: "Stop 00000050"
Back to the top
STATUSMicrosoft has confirmed that this is a problem in the Microsoft products that ar...
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section. This problem was first corrected in Windows Vista Service Pack 1.Back to the top
MORE INFORMATIONFor more information about software update terminology, click the following arti...
For more information about software update terminology, click the following article number to view the article in the Microsoft Knowledge Base:824684 (Description of the standard terminology that is used to describe Microsoft software updates ) Description of the standard terminology that is used to describe Microsoft software updates
Back to the top
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Enterprise
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
Back to the top
Keywords:
kbvistasp1fix kbfix kbbug kbhotfixserver kbqfe kbprb kbexpertiseinter KB930979
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
I appreciate the response but I don't have the BitLocker Drive Encryption feature. I am using Vista Home Premium which does not have that feature.
    Intel i7 920
    6GB DDR3
    Asus EAH4870DK
    View Sonic
    Raid 10
    Air
    Logitech Bluetooth
    Logitech Bluetooth
    10 MB
Do you have Catalyst 9.5 drivers installed? I was getting that bugcheck so I went back to 9.4 and haven't had it since.
If you attach a .dmp file from C:\Windows\Minidump , it may give a better clue what's triggering it.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Yes I have Catalyst 9.5 drivers. Thanks for the clue.
Right now it is back to BSOD after Microsoft Support helped me install SP2 again. They have bucked the problem over to Research and are supposed to call me between 9-11 am in the morning. I will suggest that to them or if they don't call back I will try rolling back the drivers.
    Intel i7 920
    6GB DDR3
    Asus EAH4870DK
    View Sonic
    Raid 10
    Air
    Logitech Bluetooth
    Logitech Bluetooth
    10 MB
there is a hotfix out for catalyst 9.5 AnandTech - Catalyst 9.5 hotfix
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM, WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
It looks like that hotfix is just for the video processing component, unless I'm mistaken.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Here is where I am at present. Microsoft screwed up the thing so much that I am having to do a complete rebuild. Fortunately I had everything important backed up. I have Vista with SP1 loaded and I am installing fixes now. Microsoft is supposed to call later to install SP2 with me to make sure it works for me. I am staying with Catalyst 9.4 drivers for now.
    Intel i7 920
    6GB DDR3
    Asus EAH4870DK
    View Sonic
    Raid 10
    Air
    Logitech Bluetooth
    Logitech Bluetooth
    10 MB
Buddy Kidd;1054881Microsoft screwed up the thing so much that I am having to do a complete rebuild.[/quote said:
Happens to often unfortunately :( I hope the re-installation + 9.4 drivers fix it for you.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Hmmm....
I wouldn't necessarily blame the 9.5 Cat drivers. I'm running them with SP2 just fine. I also haven't had any gaming issues with either installed. I've also haven't noticed any chatter about problems between the 9.5 Cat drivers and Vista SP 2, at least none here...CATALYST Drivers - Rage3D Discussion Area. So...???
You might want to keep an eye open for "other" problems.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
What was causing the problem was a USB device I had plugged in. Microsoft Update would down load a program which would activate the device and then Windows would download a driver for it and then Vista SP2 would BSOD on reboot.
    Intel i7 920
    6GB DDR3
    Asus EAH4870DK
    View Sonic
    Raid 10
    Air
    Logitech Bluetooth
    Logitech Bluetooth
    10 MB
