Printer connection problems
Paulwright97
I am trying to connect a printer (Dell 968 AIO) using bonjour on airport express, I am running windows vista home premium, I have connected the printer directly to laptop and this has worked on the system, but on occasions does have an error of 'unable to communicate' when I do plug the USB in to the airport and run bonjour it states that there is no bonjour printer available, I've turned off windows firewall, but still no joy, I do have Norton protection running, can anyone help????? PLEASE.
I'm not quite sure what it is that you're using, as I've never used it myself. But check the following.
Start> Right Click Computer> Manage> Services and Applications>Services
Make the following set to Automatic Start Up Type (Double click or right-click then properties)
Printer Spooler
Plug and Play
Good Luck :)
~Akitakara
    Dell Dimension 9200 / XPS 410
    NVIDIA 8600 GT
    Western Digital 500GB
    DSL
