hdbg62
Thought I'd give this group a try. Have had several hundred of these warnings show up every day since 05/01/08 when I started all over again with everything loaded as from the factory and even before I ever installed my HP printer. Event ID #4, checked it out on MS and it seems I have everything running properly; i.e. both "Remote procedure Call" set to auto in Services. Got another printer showing up in Properties, "Microsoft XPS Document Writer", don't really know what it is or where it came from. If it is a bad registry key can anyone tell me how I can correct this?
Log Name: System
Source: Microsoft-Windows-SpoolerWin32SPL
Date: 5/8/2008 21:34:01
Event ID: 4
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: hdbg62-PC
Description:
The print spooler failed to reopen an existing printer connection because it could not read the configuration information from the registry key S-1-5-18\Printers\Connections. The print spooler could not open the registry key. This can occur if the registry key is corrupt or missing, or if the registry recently became unavailable.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-SpoolerWin32SPL" Guid="{13E8B4F7-4D1C-4F65-95A2-39C6B26A3012}" EventSourceName="Client Side Rendering Spooler" />
<EventID Qualifiers="49152">4</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-05-09T02:34:01.000Z" />
<EventRecordID>18702</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>hdbg62-PC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">S-1-5-18\Printers\Connections</Data>
</EventData>
</Event>
Log Name: System
Event ID: 4
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: hdbg62-PC
Description:
Event Xml:
<System>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
<EventData>
</EventData>
</Event>
- Dell Inspiron 530
- Intel Core 2 DuoE4500 2.20G
- 3.00G DDR2, 667MHz
- Intel G33/G31 Express 320
- Realtec ALC888 (7.1 Channel audio)
- Dell 22" E228WFP
- 1680x1050
- Samsung HD501LJ ATA 500 G PBDS DVD+RW DH-16W1S ATA MAXTOR 320 G USB
- 5.28 Mb/s Down, 0.64 Mb/s Up, ATT Dry Loop DSL
