Solved Print Screen scrambling images
Hey guys, i'm completely new here. I have a problem when i use print screen into any application, when i paste it there are a lot of black bars going through the image. Around 15-20. It kind of seems like Vista has an option preventing me from print screening any image. This also works when i try to capture video footage on my computer using fraps or any other video program. Any ideas why this is happening?
Thanks in advance.
Go to search and type snipping tool, its better for printing and you will like it.
Snipping tool has the exact same effect when i print screen with it. grabbing an image for you. This is what happens when i use anything that involves print screening from my desktop, including snipping tool or trying to video capture. Any ideas?
Your printer has a test printer function. Use it, does it print properly?
No, it prints out the exact same image. I don't think it has anything to do with my printer? Any video image i try to capture does the exact same thing. It's basically the bars i get when vista is asking for administrative permission for a program, except it affects anything i am trying to capture on my screen. Any idea?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Another suggestion might be a corrupt or outdated graphics driver, if you let us know the brand and model # of your desktop or laptop we can find the latest driver for you.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Asrock P67 Extreme4
    auria eq2367
    Asrock P67 Extreme4
    auria eq2367
    Asrock P67 Extreme4
    auria eq2367
Solved. Forgot to update. It was my graphics drivers not being updated. Thank you very much! This was driving me crazy. ;)
Great!
You're welcome, Thanks for posting back. :)
    Asrock P67 Extreme4
    auria eq2367
