PQSERVICE Questions!!! Help me!!
danxangel
I have a gateway desktop PC ( Model LX6200-01 ), and i found out a new partition PQSERVICE in my HDD yesterday. I know it's used for recovering system to the factory default, but i want to ask:
Does it cause any problems to my system if i delete it ? ( question 1)
I've already got 3 recovery discs of GATEWAY. Last 4 days i got a Ntdll.dll error with a software ( I posted a topic about that 2 days ago ) ->Link . I tried to recover my system so many times, but that error (ntdll.dll) still appeared when i installed the software.
That software worked well several months ago. But now it's not!
After checking CMD.
Software Error.
I want to know more about PQSERVICE!
Does it affect to my HDD and cause error ? ( question 2)
If it was, how could i solve this problem ? ( question 3)
Can i restore my system when i delete PQSERVICE partition ? ( question 4).
Thanks For Helping Me.
Notice: i use Window Vista Home Premium 64 bit ( Default window go with those recovery discs ).
    Gateway 6200-1 (Upgraded)
    AMD Phenom II x4 3.0 Ghz
    Gateway RS780
    ATI Radeon 4870
    Creative
    Samsung Syncmaster 22'
    750 GB Hitachi
    Zalman, Thermaltake
PQservice is the recovery partition for your computer, typically this is where all the information for the recovery disks is stored, unless you have backed up your system completely I would not recommend deleting it. Instead, restore your system using the disks provided. if you have a second hard drive connected , you can then run a third party imaging program like acronis true backup or paragon drive backup, make a copy to the second drive, verify that it copied ok. After you know that you have an intact and working backup, you can delete the PQservice partition without any worry.
    Home Built
    AMD 6000+
    ASUS M3N78-VM
    Kingston 8GB
    NVIDIA 8800GT
    VIA
    CIBOX 22" Flatpanel & Panasonic Viera 42" Plasma
    Maxtor 250GB Samsung 250GB Samsung 320GB
    500W
    XCLIO
    Air / Fan
    Logitech MS Revolution
    Logitech G15
    10MB
