I have an issue with my current vista installation of Ultimate SP1 x64 and my Hiyatek 7 port powered usb 2.0-hub. I've been looking for similar problem and solutions but so far neither of them have worked.
The problem is that randomly all usb-devices connected to it will fail and to get windows to recognize them again I need to unplug and reconnect the power and/or USB-cable to the hub. (It's quiet the anoyance to do this and watch while vista takes its time to find your newly connected devices as your party in the game is dying from lack of healing)
I believe this to be a driver issue, I have tried the following without success:
* Remove connected devices and let windows reinstall the hub alone then reboot.
* Install up-to-date bios and chipset drivers.
* Run with different device physical connection setups and different usb-ports.
* Tried hub at other location (Win XP x32 SP2, Latest Ubuntu), both works flawlessly with same setup.
* Checked that the usb-port the hub is connected to actually is usb 2.0
* Removed NFCACHE.1
* Worked my way through all Windows Update releases
Devices I have connected currently (although all are seldom 'used' at once):
* Logitech G15 Gaming Keyboard
* Logitech MX Revolution
* Logitech USB Michrophone
* Canon Pixma MP600
* Hercules Dualpix HD Webcam
* Xbox 360 Wireless Gaming Reciever for Windows
* Sony Ericson w850i usb Connector Cable
I will continue my quest for a solution as to why my setup seemingly randomly fails from time-to-time, I'll try to keep updates coming in case this can help someone else.
* Removed NFCACHE.1
* Canon Pixma MP600
