power supply
kev s148
Power User
hi iam starting to build a new system using the antec 902 case i have got 2 power supplys in mind the antec quattro 1000 or the corsair 1000
i now the antec power supply will fit no problem as fan is on the rear of the unit
it is the corsair as the fan is on the under side of the unit there 2 pic below
picture 2 is the one i would like to do if i go for the corsair due to cable managment but will i run in to heat problem doing it that way
thank you
    home built
    Intel Core i7 920 2.66ghz @ 3.67ghz 1.3v
    ASUS P6T Deluxe V2 iX58
    6GB (3x2GB) Corsair Dominator DDR3 1600MHz@1400mhz 8-8-8-24
    BFG GTX 285 OCX
    on board
    samsung t220 sync master
    1TB samsung
    Corsair HX1000W
    antec 902
    Zalman CNPS10X Extreme Ultra Quiet x3 120mm + 200mm fans
    Microsoft Wireless Laser Desktop 7000
    6mb
    LG dvd-rw, LG GGC-H20L blueray player, Sony 2.1 speakers system, HP photosmart c5180 All-in-one Printer/Scanner/Copier (network conected) NetGear DG834G v4 ADSL Modem/Router (Ethernet) netgear GS608 8 port switch WEI Score: 5.9
If the heat is not exhausted directly out of the case, I would definitely go with antec.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Their literature -> Guaranteed to deliver its full 1000W output at 50ºC operating temperature.
That's 122 degrees Fahrenheit.
** EDIT **
Sorry, that was for the Corsair. I should have mentioned that.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
the fan on the corsair does blowing the air out of the back of the unit but will it cause me any problems if i run it like in picture 2
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
What are you debating about here? What are you asking?
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
As long as it's blowing out the back it should work just fine as in picture 2.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
~Lordbob
i was just asking if i could run the corsair power supply like in picture 2 as the fan is on the under side rather than being on the back of the unit
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
yes you should be able to do that just fine
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
You have a consensus. Go with the Corsair!
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
