Power Supply
Airbot
Does anyone know where to get a good Gateway compatible 500watt up power supply?
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
Hi Airbot, welcome to the board,
I believe a standard size PSU would fit in that unit. In making sure of that, you always can take a measurement before purchase. I don't believe Gateway will provide such information.
If the possible reason for your step up is for an addition of a mediocre gaming GPU, I heard that the built in 400 Watt PSU provides sufficient amperes.
Good luck and post back.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
I had a old eMachines (Gateway) computer, and it would accept any standard size PSU.
I've seen some computers where the manuf had changed the location of some wires in the plug. I'd suggest comparing the wire colors on the new and old motherboard connectors before installing.
Dell is the manufacturer you are thinking about. For a number of years, they used none standard PSUs which, although they had the same physical dimensions and mountings as a standard ATX unit, were certainly not interchangeable. Although the plugs were the same, the order (as well as the number of voltage lines i.e. 3.3v, 5v and 12v) of the wires on the main 20/24 way plug was different. In addition, on some units the wire colours were not standard.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Gateway has been known to do it as well - an in particularly, some Gateway models are set up as BTX cases as opposed to ATX cases, making the restrictions on PSU, while not as great as a completely non-standard PSU, still more restrictive, in that you need the cables to be a certain length to make it to the motherboard and peripherals....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks for the input guys. Is the size and wire connections the only compatibility issue with PS? Or is there some other considerations to take. Well, the OE ps is sufficient enough I guess. I have a cheap ATI HD 3450 card. It works just fine but I get the "Display Driver stopped working and has sucessfully recovered" error quite a bit often on. Not when playing games, just whenever it wants. I always update the driver and it never corrects it. I suppose it could be a heat issue?
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
It could be a heat issue, a PSU issue, or other issues, including a mobo issue - but you might want to evaluate your PSU requirements using the eXtreme Power Supply Calculator v2.5 to be sure your 500 is going to be enough.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks John, I'll try that.
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
