Hi Guys, I just joined the forums today and wanted to bring up an issue that recently happened to a computer that I service.
It runs Vista Home Premium 32-bit with 2GB RAM, 160GB, Toshiba Satellite 205D, with CA Security software and no known issues with Service Pack 1 other than some typical 10-15 minute start up time associated with Vista.
However, the problem I ran into was that after installing Service Pack 2, some kind of error or glitch started occurring. What happens is that I restarted the computer after the install, and when Vista boots to the desktop, only about 5 icons in the tray would show when usually there are 10-12 that display. So I then tried opening Internet Explorer and you see the hourglass symbol show next to the cursor showing that it is working, but then it disappears and nothing displays. No window shows for IE. I tried launching other programs and the same problem occurs. No windows would display, but in the Task Manager, I see the processes running.
So I figure the issue is related to Service Pack upgrade, so I restored to the point before the Service Pack 2 upgrade. Everything worked fine. So I tested the computer after a restart again and again the non-window launching error occurs.
I stumbled acorss some proccessing issues with CA Security software that would hog some memory, but I am unsure that it is the reason for this error. Could it be that the Service Pack may have installed improperly, thus, creating some kind of window error? Or do you think it could be related to some preinstalled program having incompatibility with the Service Pack?
I have contacted Microsoft support and they suggested resetting IE, but I don't think that is the solution. I haven't tried it yet. I sent them a HiJackThis log and they reported no problems with it. No viruses or issues to report from a Malwarebytes scan either.
Any help would be greatly appreciated. Thanks.
.I've never use truly dangerous tools like ComboFix which you surly mean.
