possible malware infection
jazz270282
Hello,
last week i brought a new laptop, it came with the norton antivirus free trial. While visiting a site (i dont remember what) norton detected a virus (again i dont remember what) norton then crashed on me and would not run at all even after following the "fixes" it suggested. Ive always used AVG free on my PC's so i uninstalled Norton and after a few attempts finally managed to find and install AVG.I ran AVG which had a few hits but all were successfully removed. After that i also tried to install Spybot however it will not fully install, i get to the final page for installation, click install and then I get a error which reads " Error Sending Request The server name or address could not be resolved"
I know I have some form of virus/ spyware or somethimg on my PC as my browser frequently directs to Myspace (which i dont use) on the first click on a link, but when i go back to my search and click the same link again it will generally take me to where i need to go- unless it is a virus/spyware/malware removal page (in which case the link is always broken)
My browser has also been opening up webpages that generally start with ad. eg ad.reduxmedia.com
At the request of a different forum i down loaded hijack this so i could get a log of my pc however the program wont run. So i have come here wher hopefully all advice will be specially tailored to a vista PC.
I am aware that i am supposed to post my system information etc however i am new to Vista and still learning the ropes, so any help in getting the process started would be greatly appreciated.
Hello jazz270282,
Run this program, Malwarebytes, i have scanned it and it is clean. If you have trouble installing or running it, do it in safe mode. (F8 on bootup)
Post your results, thank's.
(Save to your D/Load folder).
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
hello Stoneys-nutz,
Thankyou in advance for your help. I have downloaded Malwarebytes from the link provided and installed it on my PC, however the program will not run in both safe and normal mode. In normal mode i get as far as the program needing permission to continue (where i allow it to) then the mouse shows as loading for a few seconds then.....nothing.
I have AVG, Adaware and CCleaner installed as well as windows defender. I closed them down in case they were blocking the program but to no avail.
Thankyou again
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
You sometimes have to wait a while for this to load. Anyway try the other fixes and we will see.
Good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
