Pop3 & SMTP issues...
AstaLaVista
Lost in Cyberspace
Vista Pro
I am trying to help a friend who is more pc-challenged than I am set up his e-mail with Windows Mail but I don't know what the Pop3 or SMTP for those e-mail accounts are.
He uses one email from att.net and another e-mail for live.com... does anybody knows this off the top of their head? I hate to call AT&T on this as it will be like a good half an hour for them to get to the phone and M$ would be another year.
Thanks
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
You'll have to contact those ISP's for that information because each one is different. You could try live chat with them instead of emails and phone calls. I find that live chats work for me about 90% of the time. The last 10% is generally a phone call to resolve the issue. Most of the time it looks something like this:
smtp-server.xx.xx.xx - is out going
pop-server.xx.xx.xx - is incoming
and the x's are generally what come after your email address. example; [email protected]. Where the isp.com are used instead of the x's.
Most of the time when using windows mail it should auto detect the settings for you or any email program for that matter. Usually, that is some times you have to manually configure it. When you get this info print it or write it down some where for future reference's.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
You should also be able to go to the ISP web site and find that information.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Since I used to work at AT&T...the latest SMTP/POP servers I know of.
pop.att.yahoo.com - Port 995 w/SSL
smtp.att.yahoo.com - Port 465 w/SSL
You will need to make sure you type the full email address with @domain included, use all lowercase letters and change the ports and enable SSL on both pop & smtp servers. If you don't follow any of these steps, it won't work.
