plz help, im tryin 2 download and install
jasond19
Power User
im looking for atheros wireless lan adapter 7.2.0.164. i go to the manufacture site but all i get when i try to download is a wizard or a free scan, i cant find were i download just the driver, plzzz help,
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
Get it from Acer
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
im sorry it for a laptop toshibaOperating System
MS Windows Vista Home Premium 32-bit SP2
Intel Pentium T2080 @ 1.73GHz 62 °C
RAM
1.0GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
Graphics
Generic PnP Monitor @ 1440x900
Mobile Intel(R) 945 Express Chipset Family
117GB TOSHIBA TOSHIBA MK1237GSX ATA Device (SATA) 39 °C
Optical Drives
PIONEER DVD-RW DVR-K17LF ATA Device
Audio
High Definition Audio Device, sry about that, i thought i put that on there,
    toshiba satellite
should i try toshiba? i dont understand y this is given me such a hard time, im going to the manufactr of the driver, and still being pushed off to the scaners and fast fix all in 1 type companys
    toshiba satellite
Jason D 19,
Maybe this will help. First go to your control panel and select Administrative Tools. Next Computer Management ==> [CONTINUE] ==> Device Manager. Right Click Properties on the Network adapter having an 802.11g attribute. good so far???
Select the tab with "Details".
Choose Hardware IDs from the drop down menu and highlight/copy the first entry.
GOOGLE that and see if your driver turns up.
Again, maybe this will help.
Tesla Rules!
"I never had an idea that failed. However, I have had a lot of ideas that didn't work." -- Edison
B Regards,
Zeus
    IBM PS/2
    Intel 80286 (An upgrade from my Zilog 8086)
    Motherboard in computer.
    1G
    Graphics card also in computer and on mother board.
    Very crappy. Very!
    LCD (with pin number 9 cut)
    80 col
    Two 1.44 floopy drives. Yes floopy drives and a 5.5 on top.
    Not sure what that is, but I'm sure I don't have one.
    Boat anchor.
    Stored in basement.
    Roller ball and two buttons, still don't know what it does.
    Clacky like a Remington.
    Interlink works good if that is what you mean??
    Attack sub 688 rules the pacific!
I'd go with Toshiba.
Unfortunately, with laptops things can be slightly different between drivers.
If this was a desktop, I'd go right to the card manufacturer, but laptops no.
You search via the model number, i'd look but you didn't give it.
