*Please Help*! =(
BlaZinStAnG
I seem to have corrupted my boot menu when starting Windows Vista somehow. Is there a way I can change it back to default?
    Gateway FX7026
    Intel Core 2 Quad Q9300 2.5Ghz
    Intel DG33SXG2 (Intel G33 chipset)
    8GB DDR2 667 MHz (PC2-5300)
    Nvidia GeForce 8800GT 512MB
    Integrated 8-Channel (7.1) High Definition Audio
    Samsung Syncmaster 206BW
    320GB 7200RPM SATAII 320GB 7200RPM SATAII *Set up in Raid 0 configuration
    Delta 400 Watt Power Supply
    Gateway FX 5-Bay uATX Computer Case
    Default Air Cooling
    Razer Diamondback (Salamander Red)
    Gateway 104+ Elite Keyboard
    Verizon Fios: 20 mbps/5 mbps
Hello BlaZinStAnG,
Not sure exactly what problem you mean with the boot menu, but running a Startup Repair will usually fix your boot file.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
What do you mean by BOOT MENU?
Do you mean Start menu?
Do you mean starting from shut down (turning your PC on?)
Or do you mean getting online with your browser? Is it Internet Explorer? Firefox?..
Or your home page site (Yahoo, MSN, AOL, etc)?
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
