please help thank you
neo01
hello to you all i am new in here i need a little help (hope this is the right place) i was installing my farcry 2 pc game on my computer but suddenly i got a blue screen and then i heard my hard drive loose speed and automatic restart why tis happen (after the restart everything was back to normal i install the game and play perfectly) please help i am using windows vista x32bit ultimate. here is the report
Problem signature
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1037
Files that help describe the problem (some files may no longer be available)
Mini122008-01.dmp
sysdata.xml
Version.txt
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode: 1000007e
BCP1: C0000005
BCP2: 81A54890
BCP3: 8B357A30
BCP4: 8B35772C
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
Please post the blue screen error message...
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
It was probably just a glitch while finishing the game installation and may have been repaired on the reboot.
If the system is starting properly and everything, including the game, is working as it should, I really wouldn't worry too much about it anymore. You may just end up chasing ghosts for some time without really finding out what happened.
If things start to go stupid real soon, then there may be a problem but as long as it's working as it should be I would leave it be.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
