Solved PLEASE HELP! Plugged in, not charging?
ComputerAge
h@cker
I have had it with Vista. Out of all the 6 computers I have had, this is my only one with Vista and to tell you the truth, this has had the most problems. This never happened to me since recently. Whenever I plug in my computer to AC power, it shows as plugged in, not charging. I take it out for a while to cool it down, and then after about 15-20 minutes I put it back in, and it shows as fine. When I scan it with HP Battery Check (during "plugged in, not charging") it shows as "Replace Battery". When I scan it after I fix the problem (plugged in, charging) it shows as "Good". Then after approximately 2 hours it again shows as plugged in, not charging. Does anybody know why?
Thanks,
RF:)
P.S. I am still under parts and labor warranty, just in case.
    Apple MacBook Pro 13inch
    Intel Core 2 Duo @ 2.26GHz
    2GB DDR3 RAM
    NVIDIA GeForce 9400M @256MB Dedicated DDR3 VRAM
    Intel High Definition Audio
    Laptop: 32 bit Color LCD
    HITACHI HTS545025B9SA02 250GB (Internal) IOMEGA PRESTIGE PORTABLE 500GB (External)
    N/A
    N/A
    N/A
    No-Button Aluminum Trackpad w/ Mouse Gestures
    Black Chiclet-Style Keyboard (Standard US) with Backlight
    T1
    HP tx2000z
    AMD Turion 64 X2 TL-68 Gold Edition
    Quanta 305E/nVidia nForce 430
    4096MB DDR2 PC2-5300 @ 5-5-5-15
    nVidia GeForce Go 6150 64MB
    Realtek HD Audio/Altec Lansing
    250GB 5400RPM SATA
    8 Cell Lithium Ion Battery
    HP Echo tx2000z
Hello RF,
It can be a number of things wrong. You could have a bad battery, battery loose, bad charger, bad charger connection to laptop, battery to hot to allow to charge.
Since you are still under warranty, you should have them take a look at it to have anything replaced as needed. With the HP Battery Check results, I would lean towards a defective battery though.
Hope this helps some,
Hello RF,
Thanks guys, will continue to try all the recommendations. I have already contacted HP when I thought it was the AC adapter and the are sending me a replacement. Then today I chatted with them and asked for a new battery. They said they would send it to me but I would first have to try the AC adapter. If it works with the new AC adapter, they will not send the battery but if it doesn't work they will send me a battery. If that doesn't work they will follow-up. It might be a loose charging circuit on the motherboard, but as I said I am under warranty. Worst comes to worst I replace the laptop (again). I tried uninstalling and reinstalling the ACPI but it didn't work. Oh well!
    2GB DDR3 RAM
    N/A
    N/A
    N/A
    T1
Well at least it looks like they are going to take care of you on this. :)
    2GB DDR3 RAM
    N/A
    N/A
    N/A
    T1
Please let us know how it turns out.
Guess what! I got my new AC adapter today in the mail and I plugged it in and it worked fine! It is continuing to work! I guess it was a loose charging pin in the AC adapter! Thanks anyway for your help:)
    2GB DDR3 RAM
    N/A
    N/A
    N/A
    T1
Computer Age,
I'm happy to hear that it seemed to have sorted it out for you. :)
I have one more quick question. Once, my friend accidentally put his MS Duo in my slot instead of MS Pro. I got it out, but now it is damaged. The drivers are right, and a light near the slot lights when a card is in. When I put my cards in, it doesn't show, and the light isn't there. When I play with the card, pushing it in and out, the light sometimes goes on but then immediately goes off. What should I do?
    2GB DDR3 RAM
    N/A
    N/A
    N/A
    T1
I would say that it does sound like it has gotten damaged either by inserting the wrong memory card in there or while trying to remove it. :(
It's not easy working on notebooks, so you may need to take it in to a certified HP service repair center to see if they can repair the memory card reader, or have to replace it for you.
Sorry to hear this,
thanks for the acknowledgement brink, but I think I'll hold off for now. See you soon!
-RF
    2GB DDR3 RAM
    N/A
    N/A
    N/A
    T1
If the transformer is heating up that much, you probably have a bad battery. Also, it plugged in but not charging is a bad battery.
    16GB DDR667
    SAS RAID
Maybe.
    2GB DDR3 RAM
    N/A
    N/A
    N/A
    T1
