please help. Not reconizing driver =/
help me plox
{im using a different computer}:mad:
i have a gateway computer.
i used the system restore disk on my computer. it worked. but when i got to my desktop, it didnt reconize my driver. i cant go on the internet
Hi dude,
What model is your motherboard?
Steven
From a PM said:
help please.
it would let me access my desktop. so iwas told to use the windows disk thingy.
i did, everything was turning out good. then it wasnt leting me access the internet. :[ i called with linxus. and gateway. but there being wierd.
so ur my only hope.
its not reconizing my networks. like there is none anymore
Hello Help me plox,
Do you know the model number of your Gateway computer? This will help us look up the correct driver for your network device.
Ok,
Here is the driver download page at Gateway:
Gateway Support
Step1: Notebook Computers
Step2: Gateway T-160
Step3: Windows Vista (32-bit) or Windows Vista (64-bit)
NOTE: You can tell by right clicking on Computer in the Start Menu and click Properties. Under the System section, you will see 32-bit or 64-bit.
Step4: Network Downloads
Step5: click on Display Results link
Click on the top one to download and install.
To get the latest network drivers from Realtek directly, open Device Manager in the Control Panel (Classic View) after you install this and expand the Network adapters listing to see the Realtek model number and name. Post this back, and I'll post a link for Realtek.
