!!!please help. No sound!!!
DRE910
Idk what's going on but i cant hear anything. The speaker icon at the bottom right has a red x on it. When i move the cursor over it, it says, "no audio output device installed." please help me!!
Thanks, dre...
Specs: Sony Vaio PCG-7113L, Windows Vista 32bit, 2G RAM, 140GB HD,
Hello Dre,
Here are some usual suspects that you can check until we get more information:
1. Correct audio driver version is installed and shows up in Device Manager as running properly.
2. Speakers are plugged in all the way.
3. If you have a onboard audio chip, then make sure that it is enabled in the BIOS. (Azalia Codec)
4. Volume level is not muted.
