please help me! vista64 problem
veljco
Hello people. I run vista64 ultimate, 4 giga ddr2 and on system properties those 4 giga of ram are shown, but on sidebar gadgets that are used to show ammount and use of ram is only shown 3581 mb of ram. I tried several different gadgets and results were the same...3581. I realy have no idea whats going on. So if someone knows....
Type "system" in the search bar on the start menu and then click on system information.
On the first page under Total Phsyical Memory, what does it show?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0 WD Raptor 36gb 3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
According to several things I've reag your okay. With 32 bit systems some of your memory space is reserved for hardware and such and you actually will only have access to 3.2 to 3.5 gigs. With SP1 installed you can see total memory, like you do, but you only can use 3.5 of it. The only way to get past the limitation is to change to a 64 bit OS
Edit: opps nevermind me. I wasn't paying attention and se you are using Vista 64 so someone else will have to help.
it shows 4 giga. i have sp1 installed and one day ago it worked just fine on sidebar gadges 4096mb of ram was shown...now problem...i dont understand
This is where things get technical...
On some (most/all?) motherboards memory is not remapped, they just exclude memory areas where things like raid bios, vga memory and such is mapped. That results in memory being "lost". If that's the case, there's really nothing to do about it. It doesn't prevent you from buying more memory, but you'll always end up with a bit less than you have installed.
Some software will show the usable amount of memory, some other will show the amount of installed memory.. That's just the way things work.
    Home made
    AMD Athlon X2 6000+
    ASRock ALiveXfire-eSATA2
    2x2GiB DDR2 PC2-6400
    GeCube ATI Radeon HD3870 512MiB GDDR4
    Built in HD Audio, digital output
    Samsung SyncMaster 206BW, SyncMaster 940B
    1680x1050 + 1280x1024
    WDC 250GB SATA + lots of externals. :)
    Antec Earthwatts 500W
    Antec Sonata III
    Air
    Logitech G9
    Logitech G15 (1st edition w blue lightning)
    DL/UL: 50/10Mbit
I usually just use the help/about menu in applications like notepad to see what amount is installed.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    Thermaltake Armor
    Tuniq Tower 120
you didn't recently update your bios or add some new hardware by any chance? Another possibility is maybe some recent update to vista caused this?
Since even the gadjets are showing more than 3 gigs I would assume that the sticks are good. If a stick failed I'd expect the amount shown to be even smaller
I have a RAM issue too, when Windows Vista Ultimate X64 is idle, and I take a look at the sidebar, it shows the RAM meter at 48%...
Same as the poster, I have 4GB DDR2 memory.
When I take a look at taskmanager, and I count all the RAM used by processes in the processes tab, I only count 350MB...
How is it possible that 2GB is always used?
I don't have problems with my CPU, even when playing CoD4 high, it only uses about 6 to 10 percent.
    Build it myself with compatible components.
    AMD Phenom X4 9950 Black Edition
    MS-7551
    4,00 GB RAM
    ATI Radeon HD 4870
    26" FullHD LCD monitor
    1920 x 1200
    1TB, devided into 2 partitions. (Windows / Work)
    Cooler Master
    Cooler Master
    Logitech G5 Laser
    Logitech DiNovo Edge
    Soon 40Mbit
    Also have other hardware attached: - SpaceNavigator - Bluetooth - Jabra 620 Bluetooth headset
It's used by the OS for disk cache and other system related things. If something you run (like a game or an application) need the memory, the OS will release it.
    Home made
    AMD Athlon X2 6000+
    Antec Sonata III
    Air
    Logitech G9
    DL/UL: 50/10Mbit
