Please help! I lost stuff and cant find it.... lol
Marz73
Hey I just want to start off by saying I think it might be a good thing that I am having the issue with my pc that I am having just cuz I found this place. Ok! Now that I have the a$$kissing out of the way, here is my issue
I am trying to update a game (RTW) from the 1.3 patch to the 1.5 patch. The patching for 1.3 went smooth. Now the issue I am having is the newest patch I am trying to install fails and said is can not locate rome.exe.. I have installed the game a few times and even in trying to sent the install to C:\programfiles\... rather than the one that has the (x85) in it it still uses both directory locations. I think the scripting for the patch program is looking for the .exe file in a predetermined location rather than searching or letting me point to it. Does anyone know of a way around this issue. This is not the first time I have come across this it is just the more resent. I would even be inclines to open the patch and rewrite the script to point to the correct location but I have no idea of how this would be done...
    AMD Athlon 64 X2 5600+ 2.81GHz
    ASUS M2N32-SLI Deluxe Wireless
    4.00 GB DDR2 5800
    EVGA 512mb DDR3 GeForce 8600
    Seagate Barracuda 7200 @250GB x2
Did you reboot between 1.3 and 1.5? Do you need 1.4 to get that file for 1.5? The install file should have a space in Program Files. It could be a bad script. See if they fixed it.
    16GB DDR667
    SAS RAID
as per thier wevsite there is no 1.4 or rather 1.5 takes care of 1.4. I'm not sure if I rebooted however. I will reinstall and try again. Any thoughts on the scripting being not so vista 64bit friendly?
Oh! Thanks for the fast re:!!!
    4.00 GB DDR2 5800
ok I did the reinstall and rebooted the pc after the install, once again after the first patch and still get the same issue on the second patch. I found the patch on the official RTW website so I'm not sure what to try next. Thanks!
    4.00 GB DDR2 5800
Oh! one other thing off topic. SCSIraidGuru, I looked at yer website and you PC freak'n rocks!
    4.00 GB DDR2 5800
Thanks. It is still growing up....
    16GB DDR667
    SAS RAID
