Philips SNU6500 USB Network Adapter / Driver install help
Ciaron
so i recently brought a SNU6500 wireless adapter from philips only to find out it doesnt support vista :O now ive had a look around and found out that a good amount of people have got it to work and ive seen 2 ways to make it work but unfortunately failed because of one damn reason
vista knows the drivers are for XP etc and wont install them but if i get them to install it will apparently work
so how can i install the XP drivers so it will recognise it properly so i can connect to the internet.
To sum up how can i install the XP drivers while using Windows home premium 64bit
and just so you know these are the drivers - Philips Support - SNU6500/00
Hi!
I have the exact same problem as Ciaron, I've tried the two solutions that worked for previous guys... Still it won't work... I have really no idea what to do and that is why I'm asking for help here in this forum.:huh::huh::huh:
I just thought that I should mention that Philips says that it is not compatible with Vista and it's only weird that it worked for other ppl... Im going to buy a new USB network adapter and I suggest that you do the same Ciaron, if someone got it to work they must have Vista 32-bit...
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Well thanks for answer, but I saw the same reply in this forum and tried it... didnt work :confused: There was someone else who said he just opened the device manager and installed it there somehow... did as he said but it didnt work either... Anyway, Im buying a new better adapter today :geek:
Thanks! I suggest you close down this thread? :P
I'm off!
BTW SUCESSS!!!!!!!!!!!! I FINALLY GOT THE BUGGER WORKING!!!!!!!!:mad:>>>>>:D
Simple as just going into the shortcut properties, changing compatibility to windows XP sp2 and it works...fine in fact!!!
Happy Computing!!!!
Kav
:party:
I'm off!
First you hijack a thred, then try to get it closed.:mad:
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
