Phenom and triple channel memory issues
Halnz
I just read on another thread that my Phenom may not support triple channel. Does this mean we can't have 3 2GB sticks in the slots and we should get one more to even things up? (we had originally bought a 3 pack and I don't know if we can buy a single stick of that type here).
I then read that having 4 sticks of DDR3 in can cause problems too - now I don't know what to believe :huh:
My setup is...
Gigabyte MA790XT-UD4P AM3
MS Window Vista Home Premium 64bit
Galazy GF 8400GS PCIe 512MB
AMD Phenom 11 x4 810
WD 640GB 7200RPM
Corsair TR3X6G133C9 6GB DDR3
and my previous thread with BSOD problems involving RAM is here....
http://www.vistax64.com/general-discussion/232028-multiple-bsod-new-computer.html
Thanks!
No AMD cpu's currently support triple channel. And yes if you can find a fourth stick you can use it, just look for one that is the same specs as the three you already have.
The only "problems" is that it may down-clock to 800 MHz speeds with 4 sticks installed.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
i personally run an AMD PHENOM II X3 710 WITH 4 STICKS OF 2GB RAM, and never have a issue
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
So does that mean we have to only run two sticks until we find a 4th? I am so new to all of this. :o
you can run all three with no issues. what he meant by same specs was same speed. preferably same brand and everything but if you cant same speed will work
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
