PC to TV Vista Issue
Twist86
Hello everyone I am having issues with Vista x64 Ultimate and my 8800GT.
Firstly I did a lot of reading on the forums here and on Nvidia's forum and no one seems to have my setup/issue and most said "thanks its fixed" on the NV forums without listing the actual fix so that was crappy :cry:
System Specs.
Intel Core 2 Quad Q6600 @ 400x8- 3.2ghz
Evga 8800GT 512mb
2x2GB G-skill PC6400 DDR2 800
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45
TX750w Corsair PSU
Seagate ST3320620AS 7200RPM 320gb
Windows Vista Ultimate x64
178.13 is my current drivers.
I have windows defender/shadow drive/super fetch/firewall all that crap disabled and tweaked for performance and I am patched to the current updates for Vista.
I am wanting to hook PC to TV and am curious how to get around this.
I have a coax TV with nothing else so I use a old RF modulator I hook it up to the TV...then I take a 4 pin S-Video cable and hook it up to my 8800GT and the RF modulator. I then use a RCA red/white connector and adapter to hook from PC speaker jack to the RF modulator.
Now this works perfectly with my old XP Home and 7600GT system but it does not work at all with Vista/8800GT. Not even a screen flicker.
The issue starts I get the option of choosing single/clone/dual....I select Clone...I hit Apply then it flickers and is back to single. I do anything and it says "apply settings yes or no" no matter what I hit I lose clone/dual and all it shows is my PC monitor on Single.
I reboot and it is reset...rinse and repeat. Now I have tried old 175 drivers with no luck and this is using the same TV/wires so it should work.
Anyone have a clue what the issue could be?
    Q6600 400x8 3.2ghz
    XFX GTX 260 868mb 192 Core
    Hanns-G HW191A
    Seagate Barracuda 7200.12 ST3500418AS
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Microsoft Laster Mouse
    Logitech G11
    32mb download 8mb Upload
Well, I have a clue but don't know if it will work for you since, to be honest, I seem to be able to use mine from time to time but deciphering what I did is a crap shoot.
Somehow, the only way for me to be able to view a movie or TV Show from my PC to my TV is by actually making the TV my primary monitor, of course, this means that I have a hard time getting to my icons and other stuff to pause, stop, FF or RW the clip I am watching.
Again, this is not a solution but I only have to run through this nigthmare whenever I want to watch the MotoGP races, otherwise, I just leave it alone since I don't have the patience to make it work for daily purposes.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Well firstly thanks for the help but sadly I can't even get it to actually use my TV either way.
It gives me the option of monitor + TV at first then it disappears once I do anything such as clone or dual mode so I making it primary causes the same issue to occur.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
bump
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
can you tell me if you have a scart connector on the TV or RGB connections? if you have those, can you use them for connectivity? the adaptors come with the graphics cards and all you need is the yellow RCA cable to connect to your TV.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
Well I just got done messing with the RCA female blue/red/green to 7 pin S-Video cable.
It worked out I have picture but its grey...I also can't keep my monitor resolution @ 1024x768 on clone without losing picture on the TV and the option to change picture/resolution is greyed out so I can't change it.
Its a step forward at least. I can live with having to re-arrange my icons and resolution each time I wanna watch my TV however need to figure out why I can't get color to my TV now.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
it is a bit of a predicament, its not like british RF output cables, and on the RF modulator, are you setting it to a frequency that is not in use by non digital channels?
    16Mb Sky bb
Do you mean the signal in the control panel?
Only one I could get to work was under "component high definition" and on 480i SDTV. Anything higher I get a error with my monitor for "to high frequency"
Thing I find odd is my tv far as I know is not high def so not sure why it works on that setting.
Only other ones I tried was USA NTSC and Any NTSC under "S-Video" Going to go through all the other ones later once I get back home. See if any others will work.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
where do you live and what does your tv support? if your USA then NTSC should do the trick as these TVs are designed to run at 60Hz so greying shouldnt be present, if you have it set to NTSC and your using a 50Hz TV then thats why you have greying, try it at SECAM/PAL
    16Mb Sky bb
Well that is the strangest thing though...on my 7600GT and XP system what worked was S-Video ANY-NTSC and then I would go to video settings and go to TV and turn the color up to prevent my current grey screen.
I could also leave my monitor @ 1024x768 and the TV could have its own native resolution..monitor @ 75hz and TV @ 60hz made it work. Which I can't do on Vista currently.
Now the only setting that will work is the one I mentioned in my above post and I am unable to move anything for my TVs settings except for Saturation and Flicker both of which do nothing when moved to the TV.
Very confusing problem I have.
*edit*
I am from the US btw and I also have a Sansui TVS2541 but I am having issues finding information on it. Not the greatest of brands but lasted me 9 years now so I can't complain about its quality.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
Well I just updated to 181 drives for my GPU and it fixed some of the issues. I can now move the TV and Monitor to its own resolutions and I can change all color settings.
I am now locked to "s-video" option but I can't get the screen back.
When I move from USA - NTSC to Any - NTSC my TV flickers and I see a fully colored background for 1 second then it jumps back to white snow.
So now I just need to get my screen back and I am set.
Jumping to PAL gives me a 1 second grey screen then back to snow so I think NTSC is the option.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
The best way to connect PC+TV is HDMI to HDMI
I have 2 T.Vs connected in my:
Graphic Card: Ati Radeon HD 3870x2 hdmi 1080P
and they work perfect.
Monitor Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1 connected HDMI<->HDMI
and
LG32 lcd 32LB1R-ZE (clone)
    Custom Built by me.
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
and
hes on an old tv, not even widescreen, CRT?
    16Mb Sky bb
Yeah old CRT...was made back in 2000 to give you a idea. Just your normal 30 inch TV.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
sorry for disappointing you but...
Doesn't worth the trouble.
I tried the same thing before 2 or 3 years with my old nvidia 128mb and my 28'' telefunken via rca,the picture was terrible,just terrible.
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Well the thing is it worked just fine on my old 7600GT and XP system. I don't demand perfect quaility but it beats trying to get comfy in a PC chair for 2 hours when I watch a movie vs 5 feet from me being a nice 80F water bed.
I am starting to think its not a hardware issue...I am wondering if all the anti-copyright crap Vista forced down our throats is the reason. Going to try installing XP on a spare HDD and see if I get better results.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
ok mate, sorry we couldnt help you, good luck with xp though :D
    16Mb Sky bb
No problem thanks for trying :)
I figure worst case I will upgrade to a LCD TV later.
    Q6600 400x8 3.2ghz
    Hanns-G HW191A
    TX750w Corsair PSU
    Antec 900
    Xigmatek S1283
    Logitech G11
