Hey everyone, I'm hoping for some help here.
My husband's computer was set up at the release of Vista, so that's a while ago. At that time, he decided that a windows partition of 30 GB would be adequate. His computer has 2 physical disks. The second physical disk is set up just the way he likes it.
The disk with the windows partition on it is set up as follows. 30 GB for the windows partition, 15 GB for his documents (seperate partition) and the rest is also a seperate partition. The swap file is located on the second physical disk. I've recently found out that there is 9,7 GB of unallocated space on the windows physical disk which can't seem to be either added to another of the partitions OR allocated as a seperate partition (no clue why).
The problem is that windows doesn't seem to be satisfied with the 30GB anymore, not with installed programs and stuff.
We've already moved all the my documents folder, the music folder, etc, to other partitions or the other physical disk. We regularly perform maintenance such as clean disk, defrag, remove restore points. In fact, I've set the computer up so that it only takes at most 2 GB for restore points.
Ideally, what I would want to do is to resize the partitions so that the windows partition is 45 GB. However, in Vista, it won't let me do it (in the native partitioning program in disk management). It will not let me resize anything.
Even though my husband knows that I know what I'm doing, he is hesitant to let me touch the partitions, because his computer now works the way he wants it to (mostly)... he doesn't want to run the risk of losing data, or even ruining the vista install. Which is understandable. I was hoping that someone knows of a way to resize the partitions safely...and I was hoping someone could point me to a program to do so safely, with a tutorial on how to do it. (and it doesn't matter if I have to pay for the program, cos it's worth it).
My husband is already saying that he doesn't mind waiting for Win7 until this matter is solved.... but somehow, I'm doubting it will be here in time before he throws out his computer in frustration. So I would like to have a solution for him....
If anyone can help me I will be forever grateful.
- Intel Core 2 Duo E8400 3.0 Ghz
- Asus P5K Pro
- 2 times 2GB Kingston (paired) DDR2 PC 6400
- 9600GT 512MB
- Samsung SyncMaster 226 CW
- 1680X1050
- 74GB 10.000 rpm WD raptor 750 GB Samsung F1 750 GB Samsung F1 2 WD 500 GB drives
- PSU
- Recom Power Engine 600 Watt
- Case
- Apevia X-cruiser Blue
- Cooling
- Auras CTC-868 CPU cooler; 7 Zalman 120mm, 1 Papst casesooler
- Logitech wireless trackball
- 50 mbit synchronous fibreglass connection
