Package for CD Problem
Hello, I have created a powerpoint presentation in PowerPoint 2007 with actions that activate MPG and EXE files. These files are slideshows (MPG and EXE) and one video (EXE). When I run PowerPoint on my computer everything works fine. When I try to export using Package for CD I get message the following message "One or more of your presentations contain macros, linked programs, or embedded objects. They will not work in PowerPoint viewer. Do you want to continue?" I answer yes and the CD is created. The linked files are copied to the CD, however when I run the PowerPoint presentation with PowerPoint (no PowerPoint viewer) the linked files do not run. How can I get this presentation to work from a CD?
thanks.
